72cougarxr7
Apr 20, 2016Explorer
I flooded mine once and if was a bear to get cleared out. Ended up pulling the plug and blowing out the cylinder with compressed air, and installing a new plug. Proper plug is an NGK BPR6HS ( I went wild and put a BPR6HIX iridium plug in mine)
If the plug looks dry, you could take off the air filter and give it a shot of ether or carb cleaner and see if it runs off that for a few seconds. If it does, you have a fuel issue. I priced out a carburetor once, think it was only around $30.
If I recall correctly, there is a screen in the shutoff valve on the gas tank as well, might want to check and make sure that isn't clogged.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
