dieseltruckdriv
Jan 14, 2022Explorer II
DD716TED wrote:This really is the best way to drain them of gas. Even if you run them until they stop running, there is still gas left in the carb bowl to possibly gum up and clog up things at a later time. Using the carb drain will drain virtually all the gas out of the carb bowl. It isn't as convenient, but if you aren't going to use it for a few months, it really isn't that much extra time if you think about it.
Thank you for the response.. my generator does not have the run out of fuel setting on the switch..SO I just pop the cover, and open the drain screw on the carburetor and put the drain hose is a cup to drain the machine. I thought there would be an easier way such as what you have or my Yamaha generator has..
