DD716TED's avatar
DD716TED
Champion 2000 w Dual Fuel Generator
Any Champion Generator owners out there that can answer this.. My other generator is a Yamaha 2000IS and when I wasn't going to use it for awhile, I just shut the fuel valve off and let the carburetor run dry.. With the Champion there is no fuel valve to shut off.. I was led to believe that turning off the fuel tank vent valve, the fuel would run out and shut down. I have tried that but it continues to run on and on even with the vent shut off.. I want to store it for over several months. How do you run it dry or do you?
  • MFL wrote:
    Not sure of your exact model, but my Champion 2K model 100565 gas only, has a setting on control knob to run carb dry. It also has a drain, with hose out the bottom, if you'd rather empty carb that way.
    Jerry
    Thank you for the response.. my generator does not have the run out of fuel setting on the switch..SO I just pop the cover, and open the drain screw on the carburetor and put the drain hose is a cup to drain the machine. I thought there would be an easier way such as what you have or my Yamaha generator has..
  • Not sure of your exact model, but my Champion 2K model 100565 gas only, has a setting on control knob to run carb dry. It also has a drain, with hose out the bottom, if you'd rather empty carb that way.
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,249 PostsLatest Activity: May 16, 2025
