Newman1415's avatar
Newman1415
Champion 2000w inverter no power
I just purchased a pair of used inverters from a guy and he Told me the one doesn't output Power anymore. Eventually I will be using the parallel kit. I basically got that one for free and paid for the one that runs good. He doesn't know why it doesn't put power to the plug anymore, the engine still runs great. I am taking it apart to see, any ideas on what to test or look for? I was thinking the breaker switch might have tripped on him once and went for a crap. Any ideas please
  • Do they, good to know. Maybe I will give champion a call tomorrow, is it common for anything to go wrong on these where the outlet stops working
  • Be careful. The inverter genny's use VERY high voltage internally.
  • Ok, I have a volt tester, I will try to trace it using that to see where power stops
  • AFAIK either its the reset button circuit breaker, loose wire at outlet OR the inverter module
    there are no fuses or other things to cause the problem
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
