LittleBill
Oct 07, 2018Explorer
your comparing this to a honda 3k? the honda is only running at less then 70%, so it has a buffer, your running this other unit right on the ragged edge.
when does anything run perfect right at the maximum its rated for?
not to mention running right at max, i'd be interested if there is even any fuel savings compared to the 3k, not to mention the noise, inverters getting an annoying hum maxed out.
good luck with your phone call, your Kill a watt pretty much proves its **** close to spec'd rating.
not sure on the KW reading either 1300 watts? i guess thats the PF corrected value 15 amps at 115 is over 1700 watts.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
