mobeewan
Sep 20, 2019Explorer
I have a Champion 3000/3500 watt that I forgot to drain. The gas had fuel stabilizer on it. It sat in storage for almost 2 years. I checked the oil level, turned the fuel valve on, flipped the switch to on and set the choke. It started on the second pull. Ran like a Champ-ion.
If you're stunting start you might want to start by draining the gas and putting in fresh. Check the oil as usual.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
