bartlettj
Jul 28, 2017Explorer
2oldman wrote:
I think I'd check the owner's manual. There's no drain screw?
I have one.
There is a drain screw, as well as a hose, but if you drain it you'll probably spill fuel inside the case and stink up the generator. The owner's manual states to turn off the fuel valve and run it dry if you aren't going to restart it in the same day. It also says for storage, if you aren't going to run it every 30 days, after running it dry put the choke on and pull the starter rope twice to clear the jets, then remove the spark plug and put a bit of oil in the cylinder.
The float bowl on the carb is pretty small, mine will shut down within a minute or two of closing the valve if there's a decent load on the generator.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
