schuess's avatar
schuess
Champion 3500W Generator producing 190v
I have a Champion Generator Model 46515 generator that is currently producing 190 volts. The engine switch has gone bad and Champion is sending me a new one. However, I noticed the meter is bouncing around 190v and I confirmed that with my multimeter. I have checked all the wiring and it is secure. I'm wondering if I have a bad AVR? Could the engine switch not working cause this?
  • schuess wrote:
    No, it is not the dual voltage.
    The WIZ is wrong. I have the same model, which is not dual voltage.
  • My champion had a voltage regulator go bad. Company sent new one even though it was off warranty. No problems since.
  • Your version is the one with the 120/230v switch ?
    If so, it Could be a bad voltage selector switch
    Other wise yes, the avr is bad
    On the Dual voltage models
    Never switch the voltage with the generator running
  • Maybe (Moderator) The Wiz will jump in.......or
    you might post or PM "The Prof" - the "guru" of all things Champion on this thread......
    Clicky
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
