theoldwizard1's avatar
theoldwizard1
Explorer II
Sep 04, 2018
Champion 4000 watt open frame inverter genertaor
Model #100302 No sexy looking plastic exterior. Looks like your typical small job site generator. Only about 2 lbs (dry ?) more than the 3400 watt model (it does have a larger engine and fuel tank). Specs say it is a bit louder (64.0?dBA vs 59.0?dBA)
Looking for real world feedback.
  • You do realize a DB rise of 3 is double the volume...so your contractor's generator will be around 4 times as loud based on the spec you show.
    Also are you comparing apples to apples noise specs?
    - Check the distance it is estimated at.
    - Check the throttle level assumptions.
    A good chance the contractor's unit is estimated from a greater distance and at a lower throttle setting.
    Then you have fuel economy and power quality:
    - If the air/con (or other heavy load) is cycling on and off, the inverter generator will typically use much less fuel because it will throttle way back when the load is off. A traditional generator must keep the RPM up to provide a steady 60hz.
    - Related to this, inverter generators generally are better at keeping the 120v-60hz power clean. Traditional generators tend to slow down and the voltage sags when you apply a heavy load before the engine can catch up.
    10-15yrs ago, it was pretty much Honda/Yamaha if you wanted a quiet quality inverter generator...today, there are lots of options many much cheaper than the name brand, so going with the contractor type doesn't make a lot of sense.
