valhalla360
Feb 17, 2021Navigator
Gdetrailer wrote:
Are they going to be interested in dragging the gen out, checking oil level, hooking up to natural gas, pull start and then run extension cords all over the place?
If your power is going out once or twice a month or for days at a time, I could buy your argument.
If it's once or twice a year for a few hours, not so much.
We've never found ourselves in the first case.
Of course, you can do a hybrid solution. Get an electric start portable and build a vented doghouse for storage in the yard. Generally if it's not going to be weeks (never have seen that), I want the fridge, freezer, and furnace running. Maybe add the entertainment center. A portable can easily handle that. That doesn't require a host of extension cords around the house and if it concerns, you run them semi-permanent where they are tucked up out of the way.
If I was having regular power outages, I would look into if the well pump could be replaced with a 120v version.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
