public_land_hun's avatar
May 03, 2015
Champion Generator 4000/3500 trouble
Bought A New Champion Generator used It From Sep Though Feb Then Again Last Week. I've Not Had Any Issues With The Gen Until The Last Few Times I've Used It. The Problem Is The Gen Surges And Gallops Bad And Then Will Stall. I Check Fuel Bowl Lines, Air To Tank Line. No Trash Or Debris. Always Use Fresh Gas And Start The Gen Every Two Weeks. It Has 130 Hrs Of Moderate to Medium Load Hrs. Use it For My TT. Now, This May Sound Strange, But When The Gen Is Off And I Open Gas Cap For A Minute, The Put Cap Back On, it Runs Great for a Couple of Minutes, Then Goes Back To Galloping. Is it Possible The Gas Cap is not venting right? Model Number Is Champion 46598. Thanks.
  • Are you in the habit of using a fuel stabilizer during long term storage ?
    Do you use REAL gas ? (non-ethanol)?
    Fuel for thought, if you will.
  • I Tried That, But It Still Gallops Even Withe Cap Off, But Once I Put The Cap Back On It Run Fine, Then Will Gallop Again. Its Strange. Thanks For Your Feed Back.
  • It may be an ethanol issue... apparently the Hondas hate that stuff. Don't see why Champion would be any different.
  • public land hunter wrote:
    Is it Possible The had Cap is not vent right?
    Yes It Is. Run It With The Cap Off.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
