MrWizard
May 01, 2016Moderator
replace the bolts holding the rubber feet
use longer bolts to go thru the cargo rack thru the feet back into the generator frame/supports
loop a cable lock or covered chain thru the generator handles
put a removable box/cover over it when not using it, lock the cover to the cargo rack, now you have triple protection
i built a sliding drawer for mine in one of my storage compartments
slide out plug in turn on
at night, just slide it back in and lock compartment
same compartment first generator to use it
