Nov 27, 2018Explorer II
Watts Volts Hz
21 119 64
750 117 61
Remove the cover of the generator head. You will find the voltage regulator with a blue adjustment potentiometer. Adjust that to 125V unloaded.
1930 115 58
2050 115 58
2330 113 56
A Kill-A-Watt meter is only good to 1875W (15A). I'm surprised you didn't blow the internal 15A fuse. 2330W at 113V resistive load is over 20A.
