Edd505
Nov 27, 2018Explorer
theoldwizard1 wrote:
Hint a "standard flat blade screw driver will NOT properly fit the jet up that narrow passage way because they "flare" out. Using a small blade screwdriver might damage the jet. Buy a cheap screwdriver and the grind the sides so that there is no flare. Or buy a carburetor jet screwdriver.
Here's another hint: With a straight sided short screw driver the jet can be changed removing the side cover & float bowl. Carefully remove and reuse the float bowl gasket, being sure its seated in the groove before you tighten the float bowl. PS: I do not have the fuel cut off solenoid, I just turned off the fuel valve. From the picture I think a short Phillips would work also.
