MrWizard
Nov 27, 2018Moderator
You will only get 2400 watts from the 20 amp receptacle, if you want to utilize the maximum output of the generator us the 30 amp outlet. I have the same generator and it runs 2 of the heaters you spec’ed out without issue. Make a pigtail that goes from the 30 amp outlet to the typical 20 amp receptacle.
Good luck!
Do try this
i was able to do more than 2700VA on a Champion 3000 inverter genset running A/C at 105* F
and yes you MIGHT need to adjust the voltage regulator and the HZ
adjust HZ by adjusting the governor spring on the carb throttle arm
set that 62hz unloaded a meter but no electric loads
then check the unloaded voltage 122-124 is about right for unloaded
