LittleBill
Nov 28, 2018Explorer
Edd505 wrote:LittleBill wrote:
i guess im the only one who thinks its a fuel issue?
how is adjusting rpm/hz going to fix this? resistive heaters don't care about voltage or hz. if the generator is bogging out, sounds like either a restricted air filter or more likely lack of fuel from being clogged
Re jetting is a fuel issue. https://www.youtube.com/watch?v=9FVPeMh3-r0
he doesn't need to rejet at 2200 feet. it would prolly make the issue worse for him, rejetting for higher altitude removes fuel, it doesn't add it
