DrewE
Nov 28, 2018Explorer III
BFL13 wrote:LScamper wrote:
Long cord lowers load not increase it.
High altitude equal less air but same amount of fuel equal rich mixture.
Years ago I didn't understand when you told me current limiting was a way of keeping current constant. I thought you needed a way to keep the current up too. Later I got that.
So now I an stuck on how a longer cord (more R?) is less load.
Your heater or whatever on its own has a resistance R. Your longer cord adds a bit, for the resistance seen by the generator of R + a bit. Since the generator output voltage is supposed to be constant, by ohm's law the current (and hence power) is lower.
More generally, for a constant voltage source, the applied resistance is inversely related to the load. The minimum load is an open circuit, with no power being consumed; the maximum theoretical load is a short circuit with infinite power being consumed...but of course in real life you can't supply or dissipate infinite power, so something somewhere gives out, possibly with spectacular results.
