- MrWizardModeratorI got mine 12 days ago from.SuperGen, I think they are the first to offer it
So far I'm very happy, I've got over 60 hrs runtime on it
Gets a little over 4 hrs on one tank, with A/C , fridge and 20 amp battery charging from vector/BD 1093, in 101°F heat
Will power my 100 amp WFCO and fridge and the coffee pot at the same time
If I want coffee pot and MW at same time I turn off the WFCO
in the morning that WFCO is pulling a lot of watts, it can pull up to 1860w on a 20 amp circuit to charge my battery bank, If they will accept the full 100 amps, normally they don't pull/accept that much charge, but the wfco startup surge will stop/stall a 2000i dead
Normally it's coffee pot first, then MW breakfast, A/C can wait until later after WFCO brings the batteries up,
So far it does everything my 3500/4000 does, I have not tested it with my Lincoln wire feed welder , the small one that runs from a 15 amp circuit, worked with 3500, should be ok with the 3000i , remote model
One important thing for me was running our large 1150 cooking watt MW, 1650w input power, without turning off everything else in the RV, that and the A/C with fridge etc..
here's a picture, mounted in my DIY storage slide where the 3500 used to set
replaced 3500w - LarryectExplorervery interesting.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jul 23, 2025
