  • I got mine 12 days ago from.SuperGen, I think they are the first to offer it
    So far I'm very happy, I've got over 60 hrs runtime on it
    Gets a little over 4 hrs on one tank, with A/C , fridge and 20 amp battery charging from vector/BD 1093, in 101°F heat
    Will power my 100 amp WFCO and fridge and the coffee pot at the same time
    If I want coffee pot and MW at same time I turn off the WFCO
    in the morning that WFCO is pulling a lot of watts, it can pull up to 1860w on a 20 amp circuit to charge my battery bank, If they will accept the full 100 amps, normally they don't pull/accept that much charge, but the wfco startup surge will stop/stall a 2000i dead
    Normally it's coffee pot first, then MW breakfast, A/C can wait until later after WFCO brings the batteries up,
    So far it does everything my 3500/4000 does, I have not tested it with my Lincoln wire feed welder , the small one that runs from a 15 amp circuit, worked with 3500, should be ok with the 3000i , remote model
    One important thing for me was running our large 1150 cooking watt MW, 1650w input power, without turning off everything else in the RV, that and the A/C with fridge etc..
    here's a picture, mounted in my DIY storage slide where the 3500 used to set
    replaced 3500w
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
