pursang wrote:
My Champion 4000/3000 Model C46535 only has about 30hrs on it and ran perfect out of the box, these days it's been running rough or surging when the choke is fully open, it'll smooth right out with the choke at the halfway position but I'd like to get it back to running right with the choke off, any ideas on why this is happening ?
I watched the video. The engine is running lean. When you shut some of the air off it runs fine. It is in the carburator. Their is a jet or passage stopped up or partially stopped up. I would say take the carburator off and apart and give it a good cleaning. On my generator I go to the local air port and buy around 5 gallons of av gas. Then I take a gas can and fill it with half unleaded and half av gas. You don't want to run a 4cycle engine on pure av gas. But you can run a 2 cycle engine on pure av gas. I have not had any problems with gas going bad. When Hurricane Ike came through in 2008. My generator was running on 2 year old gas. You do need to run them every so often so when you need them . They will work right.
