nowgrn4's avatar
nowgrn4
Champion voltage fluctuation
I snagged a Champion Mod. #46598 3500/4000 genny from TS for $250 on black Friday. With a Craftsman digital meter my voltage varies 12-13 volts every second or so. It will read 113,118,122,126 all in around a seconds time. It does the exact same thing on each 120volt leg when switched over to 240volts or the 30 amp RV plug or regular 120volt plug. The analog meter on the genny stays rock solid on 120 or 240volts when switched.
This is over a 10% fluctuation. I'm afraid to plug anything into it.
Ideas?
  • I have the same generator and it does the same thing. When I connected it to my 5r and turned on the 15K AC my voltage meter inside the rv fluctuated like a pulse, varying the voltage. I called Champion and talked to a tech which informed me that the generator is working properly and not to worry.
    My son in law works for prevost and he said the term is the generator is hunting. He also didnt think it was anything serious to be concerned with.
    I bought this as just a cheap emergency generator, and even though I've ran it a few hrs at a time as to test, I am concerned with using it long term. I am impressed with how quiet it is for the type of generator, and it starts very easy, but like you I'm nervous about using it.
    There customer service is readily available so you might give them a call and see if you get the same answers as I did. I'd sure be interested in hearing back from you.
  • I don't know it's kind of fun to watch light bulbs bright and dim every second or so...
    You might need to put a load on it to get a true picture of the volts. I'm guessing it may not flucuate with a load. I'd try an old appliance or hair dryer with a lot of draw to see what happens.
    an autoformer would help smooth out the voltage. But then you lose the savings you got on Black Friday.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
