dougrainer
Jul 01, 2016Nomad
cmt246 wrote:
Doug , am I checking pressure to confirm matching pressure output between the two units, or the safety aspect of pulling hoses with out relieving pressure.
A little confused
Wish LCI could just tell me that this replacement option
Thanks Mike
Sorry for the confusion. ALL LCI pumps for Slides/Jacks will have the same operating pressure. I was just letting you know that GPM never factors in. I check pressure with a 5000 psi gauge to verify operating pressure. That lets me know if the Pump is at spec. You just gently crack the hose fittings to allow the pressure to seep out. Usually done in 5 minutes. use a catch pan. Doug
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
