MrWizard
Jan 19, 2018Moderator
many RVs do come with inverter/charger combo units
inverter/charger units cost more $$, use more batteries for the large inverter, need additional wiring to feed the 120vac output into the RV electrical
it will charge when the generator is running or shore power is plugged in
will switch to invert mode when there is NO 120v available,
needs extra wiring during install, to be connected to main 120v input to panel, just like the genny/shore power, needs to be after the primary OEM transfer switch, between TS and circuit breaker power panel
or rig a 30amp shore outlet from inverter and plug in your shore cord
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
