time2roll
Jan 19, 2018Nomad
I think you mean inverter/charger. You can also get a stand alone inverter and allow your converter to remain in place to charge batteries. I personally prefer separate components.
Most inverter/chargers have a transfer switch so power will pass through when plugged in to utility power or a generator. Yes everything just works normal.
Yes if the inverter/charger is on and ready it will continue to supply power if the utility is cut off or your generator stops. when the power comes back on the inverter/charger will automatically pass through power and start charging the battery back up.
Cost. And yes you should have a battery for each 500 watts of inverter as a minimum. (I read this in my Xantrex Prosine 1800 installation manual. Actually I believe it said something like 400 amp/hours minimum capacity recommended for the 1800w inverter) But we are talking about oem installation that would go by the book to operate at full capacity in general use by people that are not engineers.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
