StirCrazy
Apr 13, 2023Moderator
I solved this problem temprarly by disactavating the converter charging feature in my camper and only use my solar. I am looking at a couple different newer converters but havent found one I like yet. personaly I won't use a normal converter for LFP although there are a few that do, its not that they will hurt your batteries if you have some other means of charging them to full once and a while to ensure they are in ballance, but rather because they won't charge them properly.
most of the single stages dual stages and tripple stage converters out there are a compromize not a proper charge but you make due with what you have. thats why I just use my solar charger as I can custom program what I want it to out put and when. I do have an idea for a new setup for when it is pluged in, but I am looking for the right units for that and it involves using two seperat single stage converters.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
