Boomerweps
Apr 25, 2023Explorer
Set the flex solar panels on the ground by the TT. Hooked them up in parallel with the supplied Y cables. Just used the supplied clamps to the battery from the controller. Rather than have the converter running at the same time, I just pulled the 30TT plug to shut off AC power to the TT and the converter, rather than crawl on the floor to open the converter breaker. As I was hooking up the panels, I tested their voltage output with my meter (good), but noticed the supplied short MC4 cables had the WRONG ends on the red and black cables that I had previously hooked up red to controller positive and black to negative, like normal color coding. I had to reverse them to get the right polarity from the panels. Lesson learned the easy way this time. A meter is a must. 18vdc from the panels, 14+ shown supplied by the controller.
I actually unplugged the TT this morning, we had freezing temps and might have more and I don’t trust the really cheap LiFePo4 BMS. Glad I hadn’t run water into the TT yet. Got a partial refund yesterday, I was suppose to get the Bluetooth monitored battery, I did not. Going to move my battery disconnect to a more convenient place soon. After I receive more parts, I’ll get everything properly mounted for ease of use. I also will make a portable controller for my suitcase panel to plug it direct into the TT 10 amp Furrion inlet. I had thought there was a controller built into the suitcase, nope. That was in the power box/solar generator. I will be adding a second higher power solar input SAE style direct to my current (excuse the pun) controller.
Received my industrial strength Velcro in today, still thinking about mounting my flex panels with that to the rounded TT front. Secondary method under consideration is a PVC Pipe frame with adjustable brace for tilt.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
