Boomerweps
May 01, 2023Explorer
Made the PVC pipe frames with legs for the flex panels. Screwed them on using the panel corner grommets. Not considering putting the panels ON the TT until I get all the parts to properly wire everything inside. I just press fit it all together for size verification and it is well stuck together! No glue needed right now. I did gently hammer it snug.
While working I discovered the battery is now at 100% charge. It says that on the top mounted display. Just using the basic WFCO converter but I did hook the panels up for about 3 hours the other day. I’m not bothering to change out the converter. I’ll just buy a stand-alone charger for $40 if I later decide I need it.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
