time2roll
May 02, 2023Nomad
Boomerweps wrote:Any chance that you monitor the voltage and you see 14.2-14.4 as the low battery gets charged would indicate the existing WFCO is working properly. Mostly WFCO just goes to 13.6 with flooded batteries due to poor design. The 13.6 is fine just a bit slower and may not trigger cell balancing. The solar will complete the charge and allow the balancing at top charge.
While working I discovered the battery is now at 100% charge. It says that on the top mounted display. Just using the basic WFCO converter but I did hook the panels up for about 3 hours the other day. I’m not bothering to change out the converter. I’ll just buy a stand-alone charger for $40 if I later decide I need it.
Have yet to read a good report on the WFCO lithium converter. Others are available if/when needed.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
