SJ-Chris
Nov 24, 2020Explorer II
Wanted to give you all an update...
Note: This was the first time I had ever tinkered/fixed anything on an RV refrigerator. I do have a decent amount of other DIY experience though.
My refrigerator died. It was diagnosed to be a cooling unit failure.
I purchased a brand new Amish built cooling unit from www.RVcoolingunit.com $730 shipped.
Spoke with David who works there and he was GREAT with the info. He also send a link to their youtube video and also send a pdf explaining the process. It looked doable.
Since I was going through the hassle of changing the cooling unit, I figured I'd go ahead and replace the heating element (~$35) and also the thermister ($25) (which I think was bad).
I removed the refrigerator from the cabinet and layed it face down on my jackknife couch (which was covered with a thick blanket). I was able to remove the refrigerator and the old cooling unit in just 40 minutes. I was really surprised it was so easy, and that even included time to take photos every step of the way (so that I would be able to put it back together again) and also labeling everything and putting various parts into ziplocks with a postit note saying what it was. That came in handy when putting it back together.
Took a week to receive the shipped cooling unit. It was a little intimidating installing it...mostly because I had never done it before. I first did a test (without any of the thermal mastic or sealer) just to see if everything would fit. I would say it fit very close. It was off a little on the frame edge, but I hoped it would be within functional tolerances. Once I was convinced it was going to work, I removed it, put on the mastic and sealer, installed the refrigerator fins and put the cooling unit back on. It was a little bit of "leap of faith" because with the refrigerator laying face down at that point I wasn't 100% sure that all the screw holes of the freezer were going to line up when I had it upright again (...I had already attached the fins).
I fastened the cooling unit and then started putting all the controls and heating element back in their proper places. It was a little challenging as the holes on the new frame didn't match up everywhere on the previous frame (so I had to drill some new holes). Once I thought I had it all together, I tilted it upright and let it sit for over an hour (so all the internal liquid could settle). Thankfully, I was able to securely fasten the freezer screws through the back wall of the freezer into the cooling unit where they had a comfortingly snug fit. Phew!
Then I wanted to do a test BEFORE installing it back into the cabinet. I wanted to make sure it worked first, and I knew that if I had to make any adjustments/corrections on the back of the refrigerator, it was going to be a lot easier doing it while the refrigerator was out. I was going to first test it on 110v electric (not gas). I figured that would be easier, and also I had no way of testing it on propane until I put it back in the cabinet and hooked up the propane. So I plugged it in to 110v.I placed a digital thermometer in both the freezer and the refrigerator and the temps started out at 62 degrees. Clicked the "On" button and nothing happened. That's when I remembered....the refrigerator needs 12v for the controls EVEN IF it is running on 110v. So I ran 12v to the control board of the refrigerator and I turned on the refrigerator. This time, it lit up (phew....the first sign of life!).
Then, I waited.... I could eventually feel that the stack was getting hot over near the bottom where the heating element is. I had a brief scare when I saw a tiny bit of smoke. I wondered, "Is it all going to catch on fire?" Thankfully, after the tiny bit of smoke it stopped. Perhaps it was just burning off some of the newness of everything. The stack continued to get warmer. I took this as a good sign. I could feel inside the freezer against the back wall starting to get cold after just 15-20 minutes. During this time, I started putting the doors back on the front. The stack continued getting warmer over the next hour. Everything seemed to be working as expected. So I continued cleaning up wires, putting on thermal tape around the edges of the back of the refrigerator, etc.
It used to take about 2-3 hours for my freezer to get below 32 degrees F, and it would take the refrigerator probably 5-7 hours to get below 40 degrees F. BUT, the only time I've ever really paid attention to that is in the summer time where our usual temps are between 80-100 degrees outside. Today, our temps were about 65 degrees. Well, after about an hour and a half, my freezer was down to 10 degrees F and at about 2 or 2.5 hours my refrigerator was down to 33 degrees F. I considered that very fast and I was quite pleased. I was told that this brand new cooling unit (rather than a refurbished one) would have better cooling performance. So far, I'm VERY happy!
(Note: I have two identical RVs...2015 Thor Majestic 28as. If I have the time one of these days, I'll do a refrigerator test on the two RVs. One has the origianl Dometic cooling unit, and the other one now has this brand new Amish built cooling unit that is supposed to provide better performance. I guess that would be a good way to see the difference (if any))
So it was time to put the refrigerator back into the cabinet and hook up the gas and give that a try. I had my son help me put it in the cabinet and it slid right in. I hooked up the gas line and then did a bubble test to make sure it wasn't leaking any gas. Then it was time to try it on gas. Fingers crossed....... I switched over to gas, I heard the igniter click, click, click, click, click, click...and then that beautiful "whoooosh" sound of the gas igniting! Music to my ears. I watched it for a bit and everything looked like it was doing what it was supposed to be doing. I finished putting everything back together and securing everything as it was supposed to be.
40 minutes to remove the refrigerator and the old cooling unit.
~3 hours to install the new cooling unit and get it back into the cabinet. (there was about 2 additional hours during the install process where I was testing/waiting to see if it was working, checking on it every 15 minutes or so). In total, it was probably about 4 hours of work. Not bad for having never known a thing about how a refrigerator work before this repair. My mechanic shop wanted about $2400 to replace the cooling unit so I ended up saving about $1500 which is nice. Plus...I learned a lot about refrigerators at the same time which could come in handy later (...I own a couple RVs).
I parked it back into storage this evening and I put the refrigerator on propane to try that overnight. I'll check on it in the morning. If I have any surprises I'll post another update.
(Update: I check on the fridge in the morning and the refrigerator was holding at 34 degrees and the freezer was 7 degrees F. Stayed there all day. Looks like the fridge is at 100% once again!)
Thanks to all of you for the amazing help, suggestions, etc. I appreciate this forum and all the helpful guidance. I'll be sure to return the favor anytime I see a place where I can contribute to help others.
-Chris
-Chris
