John___Angela
Jan 27, 2016Explorer
I wouldn't recommend it for a trailer battery charging through the 7 wire harness but for the class C motorhome bunch you can kind a make it work. But you need to put in some decent size wiring. We made a direct run of 2 or 4 gauge (can't remember) from the alternator on the V10 to the 2 AGM batteries in the coach. We also put a meter in line. When they are run down we will see charge rates north of 40 amps at idle, sometimes quite a bit north. A v10 is quieter than any generator I have ever heard, ANYWHERE. Fuel usage is around 1/2 gal an hour. Wear and tear, couldn't give a care. I bought it to use it. It already has over 150,000 K on it and a couple hundred hours idling probably won't hurt it. Beats hauling around a generator and fuel, neither which I have room for.
Having said that we have around 400 watts of solar on the roof, which works great until you have endless days of rain.
Too each his own.
Too each his own.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
