BFL13 wrote:
Muddydogs wrote:
I'm wired up with around 6 feet of 4 gauge between controller and battery's. Controller seems to be showing the same voltage as my voltage meter but I will keep an eye on it to make sure its not running a little hot.
Eventually I will pick up some group 27 battery's but do to certain events and my lack of paying attention I ended up with 2 24's. Learned another lesson in life.
Thanks for the help guys.
The controller's voltage display and ammeter display are accurate on mine. It is the voltage adjustment setting that has the index error mentioned.
To be clear, you set whatever and let it run till voltage stops rising and stays there. The difference between that actual voltage and what you set it at, is the index error to correct for.
Ok I understand now, thanks for the heads up.
