Muddydogs wrote:
my controller also has Floating charging voltage adjustment I don't understand.
Floating voltage adjustment is - mostly - for when you change the battery to a different brand/model/type.
Muddydogs wrote:
Another question you brought up, I was planning on using the load terminals off the controller to hook up a 12 volt plug to charge cell phones at night. Controller is in the bedroom and I would like to charge my phone at night so I was thinking the easiest way would be to hook into the controller load terminals then to run more wire.
I think the easiest way to charge small electronics is via their OEM wall wart and a cheap inverter like
this one. Doesn't matter day or night.
