Jonnygsx's avatar
Jonnygsx
Charge Controller Installation location
Getting ready to start the install of my solar system and I am trying to figure out the best mounting/wiring options. I have the Xantrex C35 charge controller. My trailer is a prowler with a large front propane cover.
While this cover is not weather tight it does greatly cut down on what things underneath are exposed to. Do you think it would be ok to mount the Xantrex controller up under that cover nearest the batteries? That way it wouldn't require a separate temperature monitor and it would also give me the shortest run cables to the batteries. Thoughts?
  • I think the whole temperature compensation thing is way over-blown for many RV applications such as the OP's. IMO it is just the fine tuning of something that is so rough and ready in the first place that fine tuning it becomes pointless.
    I don't need any temperature compensation for the five month stretch off-grid we do using solar in the sunny half of the year. Can't see that anybody else needs it very much either! :)
  • Hi jonny,
    No.
    Jonnygsx wrote:
    Well isnt the temperature of the batteries primarily going to be from the air that they are exposed to? I would think that having a charge controller a foot from your batteries they would be within a few degrees of each other at the most?
  • It is the temperature of the battery that matters, not ambient temperature. Come on, it's no more than $30 for a battery temperature sensor. Get one, your batteries will thank you.
  • EsoxLucius wrote:
    Yes, that would be an acceptable place for the controller if it will not get wet there. The controller should be as close to the batteries as possible. I think you are mistaken about not needing a battery temperature sensor just because the controller is near the batteries. It is the temperature of the batteries that is important not the temperature around the batteries.
    Im just not sure how dry it is in there. There is no siding on the wall inside the cover but there is some kind of coating so its not bare wood in there, implying that it may get some moisture in there occasionally.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
