HiTech
May 18, 2013Explorer
Yes if putting 3 in series at 6v gets you to 18 v nominal and the Voc in series is withing the controller limits that should work fine, as long as the current is within what the controller can do.
MPPT is certainly the most output, the question is always by how much? If cost were no object I would have an MPPT controller rit now, just for the programmability, since many of them seem to have the most ability to customize the set points and duration of each phase of charging.
Jim
Jim
