TurnThePage
May 20, 2013Explorer
smkettner wrote:
Yet no actual PWM models are suggested. As if all PWM is all the same.
YES!! I totally agree! Aside from Salvo's link below, nobody has really suggested a PWM controller. Especially one that would be considered reputable, yet cheap enough to be a viable alternative to MPPT.
Salvo wrote:
That doesn't sound right. You mentioned Voc = 21V. Connect two panels in series and you get 42V, not 12V.
As mentioned before, your best bet is to connect panels in parallel and use a pwm controller.
http://www.ebay.com/itm/5-30A-Solar-Charge-Controller-Regulator-12V-24V-Battery-Charging-PWM-Solar-Panel-/221142180373?pt=LH_DefaultDomain_0&var=&hash=item337d19e215BillyW wrote:
As for the 6 volt comment, if they are in series, they should be equal to a 12 volt panel.
