time2roll
May 21, 2013Nomad
The only rules I have programmed are extending the absorption time based on start voltage. That might be the extent of it.
Pretty sure you can adjust the temperature compensation factor. But not separate rules above a chosen temp.
MS View software can be downloaded and programmed on any PC. When you have it right you transfer the settings to the controller.
