smkettner wrote:
Salvo wrote:
That doesn't sound right. You mentioned Voc = 21V. Connect two panels in series and you get 42V, not 12V.
As mentioned before, your best bet is to connect panels in parallel and use a pwm controller.
http://www.ebay.com/itm/5-30A-Solar-Charge-Controller-Regulator-12V-24V-Battery-Charging-PWM-Solar-Panel-/221142180373?pt=LH_DefaultDomain_0&var=&hash=item337d19e215
Now I see the concern of dropping to float early.
14. Boost Charge Voltage: 14.6V; x2/24V(time of duration:10 minutes)
15. Direct Charge Voltage: 14.4V; x2/24V(time of duration:10 minutes)
I am happy with my LandStar 20a PWM controllers of the Series three stage (vs older type Shunt on/off method). I was concerned the two- hour timed Absorption Stage was too short, but it is working out in real life no problem.
After a month now on solar, the batts are fine and even their SG is staying up near baseline, indicating that longer Absorption time at 14.8v is not required.
One set of 6s needed water while the other didn't (the Exides, not the Interstates) and after a few days of normal solar after adding water, the SG reading on those had caught up, indicating sufficient agitation---I did not expect that, so I am extra pleased.
As I have said before, MPPT is some kind of scam IMO, where "they" target gullible techno geeks for their money. Or perhaps the target is the same guys who want STP, F-310 in their gas, or a Tiger in Their Tanks!
Who knows. Anyway, Salvo is right. You can't do better than perfect, and I am getting perfect with my "cheap-Chinese" PWM controllers (that work perfectly and are well-built--sorry about that! :) )
I don't know where you buy them in the States, but I suppose Google knows. Here is the manual for interest--BTW the same guy seems to write the MorningStar manuals and uses the same diagrams---and everyone likes Morningstar and hates cheap Chinese stuff. :) (LandStar, MorningStar, AfternoonStar---tee hee ) It's your money and you are over 21.
http://www.pvsolarchina.com/wp-content/uploads/2012/09/User-Manual-of-LS1024-LS1524-LS2024-Solar-Controller.pdf
