Fisherman
Apr 02, 2020Explorer
Bond the Generator outlet if it allows or make a special generator adapter with neutral and ground bonded.. IF YOU DO NOT KNOW HOW. Get help from someone who does.
Take a common 120 volt AC plug, open it up and put a 14 ga jumper wire between the green ground screw and the silver screw where the white or neutral wire goes. Close the plug and insert it into one of the 120 volt receptacles. Now it's bonded. It was mentioned here before with a couple of pictures but I can't find it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
