HappyKayakers's avatar
HappyKayakers
Explorer III
Jan 01, 2022
Charge controllers
I'm a fulltimer and my 2017 5er is almost always hooked up to shore power. I have 2 12v batteries. I 'believe' one is strictly for the inverter circuit (residential frig and possibly WH). The other batt powers everything else 12v in the rig. The converter cables go to a Magnum Energy Smart Battery Combiner for charging. I'm having some charging issues now that are just confusing the sh** out of me but here's the question I would pose to folks with more electrical knowledge. Would it be beneficial to change the current setup to use 2 individual charge controllers instead of going through the combiner?
  • pianotuna wrote:
    Hi,
    Generally speaking it is best to have both batteries in parallel, assuming they are identical in chemistry, amp-hours, and age.
    Charge controller is a device used in the solar industry. Do you mean converter? or inverter/charger?
    May I ask you to share the problems that are occuring?
    From the factory, the batteries were placed on opposite sides of the compartment and treated as separate power sources.
    The Smart Battery Combiner gets power from the converter then apportions it between the batteries.
    The problem I'm currently having is that the SBC will not operate continuously. It's designed to operate within certain voltages. At times it will give a low voltage disconnect indication and stop charging either battery. I've already replaced both batteries. I've been using a standard battery charger to charge the main house battery when the SBC quits. I think tomorrow I'll try hooking up that battery charger on the outbound wires from the converter. If the SBC works fine that way then I'll know that I also need to replace the converter.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I will second Piano on this.
    There is a little known battery rule Peukert's effect
    The short version is this: The faster you draw down a battery the faster still it runs down,,,,
    So if you are drawing say a steady 10 amps a 200 amp hour battery bank should hit half full 10 hours down the road. "
    Now you would think if you parallel two such banks for 400 amp hours total it would take 20 hours to get to half full but surprise, suprise, it takes LONGER,
  • Hi,
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
