otrfun's avatar
otrfun
Explorer II
Oct 20, 2013
Charge Current Questioin
With no load on the battery, converter on (WFCO 8955), and battery discharged to 11.9 volts (I know, not recommended), I read 29 amps of current on the negative battery lead (hard to access the positive terminal). This dropped to 22 amps about 30 minutes later.
1. Can I assume this is charge current?
2. Typically what is the maximum charge current when charging at 13.6 volts?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
