otrfun
Oct 20, 2013Explorer II
Charge Current Questioin
With no load on the battery, converter on (WFCO 8955), and battery discharged to 11.9 volts (I know, not recommended), I read 29 amps of current on the negative battery lead (hard to access the positive terminal). This dropped to 22 amps about 30 minutes later.
1. Can I assume this is charge current?
2. Typically what is the maximum charge current when charging at 13.6 volts?
Thanks!
Thanks!
