Jim_VA's avatar
Jim_VA
Charge dead truck battery (LA) from house battery (LiFePO4)
Recently I was in a very remote area when my "check guages" light came on indicating the alternator wasn't charging. It eventually came back on (could be a bad ground?). I had a similar situation last year in central Idaho but in that case my alternator actually did die -- fortunately 5 miles before the only town for many miles and with an hour of daylight left. It got me to thinking about options should the truck batteries ever drain down. My house battery is a 200aH LiFePO4. I've been looking to the internet for answers but so far nothing related to this type of situation comes up. How could I safely recharge my truck batteries enough to get me back to civilization? Any thoughts?
  • You could use jumper cables to parallel your house battery with your vehicle battery and let it charge your vehicle battery BUT LiFePO4 batteries are not made for starting heavy motors, like an engine starting motor. The power surge could cause the BMS to shut down the house battery, then you’re really screwed.
    Most auto parts stores will test your battery and alternator because they want to sell parts. Let them test it.
  • Bobbo wrote:
    If you have a built in generator in your RV, you could carry a small 120v battery charger. Otherwise, you can carry a battery powered jump starter like this one:
    Jump Starter
    How would a jump pack or a jump start help a dead alternator?
    (It won’t).
    The only logical choice here is your other suggestion. Fire up a genny and fully charge the starting battery(s) and then drive to town, or drive til they’re dead and repeat the process.
    Not a logical option to try to “charge” batteries from another battery. The even if it works somewhat, they will just equalize and best case you have 2 - half dead batteries. (Or 2 - 3/4 dead batteries in the truck and 1 half dead bigger battery in the camper. At that point save the camper battery so you can keep the lights on and beer cold for a while, while you’re camping on the side of the road. Or swap that big camper battery into the truck somehow and hope you get to town before the truck dies again AND the beer gets warm!)
    BUT, here’s a crazy thought, ditch the (likely) cheap reman alternator you put in last year. Either find (not easy or cheap) a quality NEW alternator, or have the current one fully rebuilt at a local shop. Unless the reman was already a totally old and cooked alt, bearings, brushes and diodes and she’s good as new.
    To explain further, remans are (I’ve learned) largely horrible because they are not “rebuilt”. They get whatever broke replaced and sent back out in a new box. And they virtually never get new diodes, which is likely (almost certainly) the cause of intermittent charging.
    So in short, spend no time on concocting an elaborate band-aid and just fix the actual problem correctly.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Jump Starter
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
