OnaQuest
May 25, 2013Explorer
The 1999 Jamboree may very well have a diode based battery isolator. If it does, then maybe the trik-L-charge is the way to go. If the Jamboree has a BCC, like the Fleetwood Class As do, then you have a malfunction to contend with, and not a design deficiency. If your rig has a simple solenoid isolator that closes on ignition signal, then MEX's suggestion of a BIRD relay is a very good approach.
