- SFVdaveExplorerGoing to call Battleborn tomorrow. They told me last week that they specifically adjust the voltage down to 14.3v . This is 14.6v.
- FWCExplorerEven if the voltage is adjusted down to 14.3V, that is still WAY too high for floating the battery. The whole premise behind the converter is wrong.
- hpdrverExplorerIf you have a progressive 3 stage charger and plug in the progressive charge pendant you can charge lithium batteries. By pressing the charge pendant, the charger will go into boost mode 14.6 volts and after 4 hours return to a safe 13.6 float charge. Progressive recommended this to me instead of replacing the charger with the lithium charger.
hpdrver wrote:
Must have figured out they made quite an error on this.
Progressive recommended this to me instead of replacing the charger with the lithium charger.- SFVdaveExplorer
That's is what I have been doing. Not happy about a constant 14.6v and possibly frying my appliances. Also have a 200 watt Renogy inverter attached to the batteries. Not sure how it likes that voltage either. - otrfunExplorer II
hpdrver wrote:
I believe most (if not all) 3-stage Progressive Dynamic conventional type converters/chargers made by Progressive Dynamic bulk charge at 14.4v, not 14.6v.
Some of the 3-stage PD converters are conventional/Lithium switchable. You can choose conventional charging at 13.2v/13.6v/14.4v or 14.6v lithium single-stage charging, but not both at the same time (if it did have this capability it would make it a true 4-stage converter/charger). - otrfunExplorer II
SFVdave wrote:
I believe hpdrver has a conventional PD 3-stage converter (13.2v/13.6v/14.4v; each selectable using the Charge Wizard). If he has the PD converter that switches between conventional 3-stage and single-stage 14.6v lithium, it will not drop to 13.6v in the lithium mode. He must select conventional than use the Charge Wizard to select 13.6v.hpdrver wrote:
Have you had a chance to verify the voltage output of your PD4560Licsv when you switch modes with the Charge Wizard?
Don't believe Renogy currently makes a 200w inverter. Did you mean 2000w? Most Renogy inverters have at least a 15.0v input rating. Some are rated as high as 16.0v. - SFVdaveExplorerShould be 2000 watt inverter from Renogy.
- 3_tonsExplorer IIIThe PD Lithium specific model is extremely flawed...Why??... Because it continues to charge the battery long after the battery is fully charged (eventually shortening battery life) and cannot be shut off without entirely disabling the 12v converter only function.....This is why their regular model is better, while it’ll deliver the necessary 14.4v when using the Charge Wizard set to Boost, and the 13.6v Absorption will be of no consequence...However, Equalization mode will need to be defeated....
3 tons - otrfunExplorer II
3 tons wrote:
The Progressive Dynamic EQ mode only applies 14.4v for 15 min every 21 hours before dropping back down to 13.2v or 13.6v. Battleborn only expressed concern about floating their LifePo4's at 14.6v 24/7, weeks/months at a time. Very significant difference.
3 tons
IMO, anyone with a LifePo4 who has the need to leave their rig unattended for weeks, months at a time should simply disconnect them--ideally with a 40-50% SOC, regardless what kind of converter/charger they have. With a parasitic discharge rate of only 1-2% a month, they'll be fine for a very, very long time---at least a year or more. Even 13.6v will quickly float LifePo4's to 97-98% SOC. Unless I'm missing something here, what's the point? Is it possible this is the reason Progressive Dynamic designed a single-stage 14.6v converter to begin with? They saw no urgent need to float a LifePo4?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
