wopachop's avatar
wopachop
Charger and Solar controller not meshing well?
I have a WFCO charger and Go Power charge controller. I can get model numbers later and also check my manual.
This morning with the charger and solar both connected, I had 2 amps of juice running backwards from the batteries to the controller. Using a clamp meter to measure i can tell the direction the power is flowing.
Here is the sequence.
1. Solar connected. Charger disconnect switch is Open. Trailer on shore power.
2. The solar display is showing 14.7v. Power is running from the solar controller to the batteries with enough amps to maintain 14.7v.
3. I close the disconnect which now means the charger and the solar are connected to the batteries.
4. Immediately I notice the solar display voltage drop to 13.5v. The WFCO charge wire is now giving amps to the battery. While the power on the solar charge wire is now going backwards. 2 amps are being pushed back from the battery to the solar controller.
5. I open the disconnect switch on the charger and voltage goes back to 14.7v with power going from solar to batteries.
  • jdc1's avatar
    jdc1
    Explorer II
    BFL13 wrote:
    You should have the controller's pos and neg to the battery independent of the WFCO charger's pos and neg to the battery. (WFCO neg might include some frame which is ok)
    You have a wiring issue.
    Correct. The solar thinks the battery is charged.
    BFL13 is also correct with his second answer.
  • Do not use the controller's load terminals. Use the Batt terminals only for output.
  • Seems like GP is going to float. Very odd for a solar controller to absorb 2 amps unless it has a secondary charge circuit that is connected.
    Or just leave the WFCO off.
  • You should have the controller's pos and neg to the battery independent of the WFCO charger's pos and neg to the battery. (WFCO neg might include some frame which is ok)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
