MEXICOWANDERER
Aug 21, 2014Explorer
greenrvgreen wrote:
I'M BUYING THIS UNLESS SOMEBODY SHOUTS "STOP":
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=202060&catalogId=10001&CID=GOOG&gclid=CIa8karDosACFYqBfgod_B8A8g
14.3 to 16.5 voltage adjustment range is OK if the unit is solely going to be used as a battery charger with a protection shut off timer.
Running the positive output lead through a silicon rectifier will drop voltage .7 volt, and sags the minimum from 14.3 to 13.6
A cost effective performance accessory to think about.
Someone recommended the Iota because it has double the output. I wanna see the Iota work with a 450 watt generator. Then we'll go to the US patent office. I'll drive...
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
