DaHose's avatar
DaHose
Charger Upgrade Question
Hey everyone. I am looking to add big battery capacity to my RV and the question of a charger upgrade has me a bit "perplexed". If you installed something like a Progressive Dynamics 9200, did you buy a unit that slides in and replaces your existing charger module or did you get the one that plugs directly into 120V with a traditional cord? I have been looking around and it seems PD doesn't make the 100A units in the form factor that slides into the OEM location. If you installed a 100A 9200, did you just ditch the built in unit from the bottom of your power center, replace with the 9200 and run a new cord to a 120 outlet? Or do you re-use the 120V feed to the OEM unit by putting a female socket on the cables?
For the curious amongst you, I plan to run a new set of 4 gauge wires directly to the new 6V batteries (in series for 12V) as well.
Jose
  • This website might help you... 4 ga wire for a 30 amp circuit sounds excessive.
    http://www.powerstream.com/Wire_Size.htm
    Consider watts first to determine amps in planning wire gauge size.
    A 100 amp DC charger is 100 amp * 14.4 volts = 1440 watts. Lets round that up to 1500 for some fudge factor. 1500 watts / 120 volts = 12.5 ... round that up to 15 again for fudge factor and there you have it... so 14 gauge wire should be sufficient for the charger, and a 15 amp circuit breaker in your distribution box.
    Another example: If your battery bank is going to power a 2000 watt inverter (4000 watt surge), the math would look like this: 4000w / 12v = 333 amps. Looking at the chart in the website above, that is 4/0 cabling. You'll also want a 300-400 amp class-t or better fuse on that cabling.
  • Don't forget the power factor. The PD9280 spec calls for a 20a CB and 12 wire because the unit has a PF of 0.7 that adds a bunch to the "watts" (VA actually) drawn from the generator or other power source.
    PF corrected converters start at the 75amp size so they can still run from 15a circuits
    Use the "divide by 10" rule for the DC amps draw of an inverter. An inverter running a "1000w" appliance will draw about 100a DC.
    (Except with microwaves. A PSW inverter will draw that but a MSW will draw fewer DC amps to run the same MW because it also isn't running that MW at its full power due to the MSW)
  • DaHose wrote:
    Hmmmmmmm ...... sounds like running some fresh 4/3 romex from the 30 amp plug to the new charger and then some 4GA wire to the batteries is what needs to happen.
    My genny is a 4K Onan, so load shouldn't be an issue. Although, running the charger and the A/C at full bore might be an issue or trip breakers. Maybe a 60 amp
    Jose
    4/3 romex ?? Where did that come from ?? Maybe you meant 14/2 w/G But I would use 12/2.
    And I think I would take it off the ac distribution panel, not the 30 amp plug ! Actually, the 15 amp 14ga circuit feeding the old converter would run a 9260
  • I looked at the specs. on the 9200 and it listed upwards of 80 surge amps on what looked like the 120 side, so I looked at the wiring charts and got that wire spec. If I were to come off the plug, I would add a dedicated breaker.
    Yeah RJ, I meant 14/2 w grnd. (14/3). Now that I think about it, I'm pretty sure I have a spool of 12/3 in the shed. If the 15A that feeds the existing converter would be appropriate for a 9200, I could just use the 12/3 and not use the spare lead.
    Jose
  • I used the PD4655 which was a 55 amp drop in replacement for the Magnajunk 7345 that came in the RV rather than a 9100/9200. I did upgrade my wires to the batteries to 4g from the 8g that the OEM used.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
