ksg5000
Mar 05, 2015Explorer II
If you water pump works when directly applying DC then chances are you either have a defective switch or monoplex controller/relay needs replacing - mine burned out when when the converter went bonkers. Edit: Also if you converter is working but your batteries aren't charging you might look for a blown fuse or auto-reset circuit breaker usually located near batteries.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
