Empty_Nest__Soo
Oct 21, 2014Explorer
Thanks for the quick replies.
Yes, I thought I recalled a need for balancing the charging, but then I found the current wiring to be a bit different than expected.
Before buying the 1093, I looked up the user manual and found that the draw is 785 watts continuous, and I knew that the ef1000is had a rating of 900 watts continuous. Closer than I would have preferred, but I figured it would power the charger. I also assumed that I could dial the charger up only to 20 amps if necessary to hold down the draw from the little genset.
Wayne
Wayne
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
