MEXICOWANDERER
Oct 21, 2014Explorer
13.6?
Ask the "battery-scientist" for his credit card at the gas station.
BFL's answer is the closest to realistic common-sense. Around 25 years ago I "deeply offended" an engineer at a battery OEM when his self-importance led him to start making some oddball charging profile statements.
Do you. yourself, use batteries in an off-grid environment?
No
Have you personally conducted extended cycle testing on your products?
Well, no, but...
But what?
I perform BCI CCA, reserve and 20 hour tests on a regular basis
How about cycle life testing?
We send those out.
Do you have an RV?
No
Do you have an off the grid cabin or vacation home?
No.
Then the engineer will go on to write a protocol published or not for that company's battery care and maintenance. He relies on rote, borrowing information from other manufacturer's who may or may not be doing the same thing themselves. The folks who manufacture 2 volt cells have genuine testing labs. They have to.
Then into the middle of this parachute drops inquiries for construction and programming information recommendations for converters.
The only converter program designer I have personally run across that has a clue about how to deal with heavily cycled batteries is "Randy" at Best Converters. Never met the man, but his "Boondocker" makes more sense than anything else I have seen so far.
No
Well, no, but...
But what?
We send those out.
Do you have an RV?
No
No.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
